I have an outside light wired directly into the consumber unit. neutral going to the main switch and the live going to one of the lighting fuses.
I want to put a switch in so that I can control when the light comes on. I thought the previous owners had already done this but when i opened up the switch it turned out to be for the alarm witch was still live and I blew the main fuse by the meter. E-on came out within the hour thank god.
My own stupid fault for not doing a proper check of what was still live and what wasn't.
If i switch off the main switch I can safely remove the neutral/live wires? From my understanding if the main switch is off the only thing live in the box is the 2 wires from the meter that go into the main switch, is that correct?
