I am about to install a new Neff B1861 single oven and a separate Neff B7881 microwave combi oven above it in a housing unit. At the same time I will also be installing a new Neff T1443 ceramic electric hob. The kitchen has just been built. The electrician replaced my old consumer unit with a new Crabtree mcb type. The hob has been provided with a separate 32A (6mm cable) supply via an isolation switch, so far so good, but it’s the oven & microwave that I need help with.
The single oven unit has a rating of 3.5kw (no cable or plug provided) and the microwave combi oven has a rating of 3.6kw (3 core flex supplied, no plug was attached). Both units in the instructions say they must have an isolation switch and the oven must use a H05VV-F mains connection cable which I have been told is also 3 core flex.
The electrician has provided one double switched socket outlet behind the oven housing which is connected to the kitchen 32A ring main.
From what I’ve read in the forum, both the oven & microwave working at full load can pull 30A? So what are my options?
Can I provide a switched fused spur (FCU) from the 30A ring main (from the double socket behind oven housing) to supply the microwave.
Then, from what I understand, the hob’s electrical connection point allows connection to another/other appliances. Could I then run a 2.5mm T&E cable from the hob to supply the oven via a switched FCU?
If this is possible, what size fuse rating would need to be fitted in the FCU’s?
Apologies for terminology used, not had to do this for a while.
I would be most grateful for any help or suggestions….thanks….
