Hi All,
I have a megaflow in the loft together with a hot water circulating pump that is not working.
It used to work but was a bit noisy and I didn't really need it so I turned it off (it has a fused switch). Now, having recently become a father, and thinking it would be quite useful, so at the weekend I turned it on again. And it worked OK.
Now a few months ago, I also had some problems with my boiler not switching off, that I traced back to, amongst other things, the froststat (thanks to those who helped with that), and I disconnected it intending to replace it before the winter.
Well being on paternity leave, I've been in the loft trying to replace the froststat. And now the pump doesn't work anymore.
I've traced the wiring through, and it seems the circulation pump receives its power from two sources. One being the froststat itself - and presumably this wont activate until it gets too cold.
The other source is from a connection in the airing cupboard I think, although I can't actually see it, thats just a guess based upon where the wire disappears out of the loft. This wire is a Red/Black/Earth type but not particularly thick, closer to domestic lighting weight. In the airing cupboard there is two immersion heater switches, the time hw/ch timer unit, and a blanking plate that covers lots of wiring connections that I haven't traced through.
I can't figure out what the power source is connected. Am I missing something here? Is it only powered when something else is turned on? If so, I can't figure out what. Is it possible the previous owner has been up in the loft and screwed it up? Is it possible a fuse has blown hence another reason why the froststat has blown?
If anyone has any insight into this, I'd be grateful.
Smashy
Smashy
