Hi all, I can see many threads about wiring in and at a hob but my query more relates to the wiring connections before the hob, please.
I have a correct capacity cable (single as a radial supply) from fuse the box and routed near to the hob but not wired in to anything yet.
My question is, would the wire go straight in to a 45A Double Pole Switch (supply) and from there to the hob (feed), or should there be another connection somewhere in the run, especially if there is no local fused plate used anywhere for this?
Additionally and for future use, the 45A DP switch will be in a tiled wall, so cables buried behind that...so if ever changing again in the future I take it that the existing wires that meet at the hob are simply switched to the new one (capacity allowing etc.) rather than anything within the switch.
Johan
Johan
