Wiring up a baxi bermuda vp firefront.
3 May 2008
Cardiff
Hi,is there anyone who can help me with the wiring of my baxi bermuda vp fire front.We had it fitted second hand by a corgi registered plumber who after fitting it told us that he wasnt qualified to wire up the lights has he didnt have a certain certificate.i now have a lovely fire that has no lights.I do have a book that came with it that shows wiring diagram but it mentions a permanent live and a swithed live.I am not sure whether the switched live is fo the boiler or the lights.Can anyone help.Information or a written diagram would be great.Thanks.
The booklet you have has all the information you need.
If you're not confident with electrics, get someone in who is!
Job for an RGi as complete fire front needs to be removed to wire up in accordance with man's spec's. The perm Live and switch live are fed to a plug located within boiler area.
If you don`t have lights then you wont have power to the ignition either. Although book says connect to boiler elec plug the chances are it wont have a permenant live to it anyway,so this will need adding.
Otherway of doing it is to stick a 3 pin plug on it doesn`t adhere to regs but loads like it
Thanks for all your replies.Unable to check whether we are able to use ignition switch yet as the plumber as had to order a pipe for the bottom as the other was too short,but interesting comment.Please could someone tell me if the switched live or the permanent live is used for the lights.Thanks
If lights are on a permanent live as I suspect does this mean that the ingnition for the fire is also connected to the permanent live also.Thanks
Permenant live to fire will supply power to both lights and ignition
