Hi, I need some help plz, I'm fixing a single oven with 2,2KW as the total load. I'm using 1.5mm2 size cable and the instruction manual notes that a 16A minimum should be use. I would like to know if I can connect the cooker to the ring main which has 30amp at the CU. And I would like know what type of double pole socket should I use? And is it possible to purchase a 16amp fuse like the one you find in household plugs(13amp)?
colle
colle
