I’m just about finished with my shed / man cave, and will at some point soon be needing it all wired up.
My plan is to put in the circuits, mount the socket boxes / lights and consumer u it’s, run the cables myself, then have the local electrician in the village connect it all up.
From the house to the shed 4 mm SWA, possibly 4 core so later I can extend a separate outside lighting circuit out there - to be buried for approx 20metres to the shed, go into a junction bow on outside of shed.
Internal, light circuit, done in 1.5mm twin and earth, and a ring main done in 2.5mm (feeding 5 double sockets, with maybe max 3kw at one time.)
Have garage type consumer unit in the shed. Making sure it has RCD - should this be at the House end?
I’ll be discussing with the electrician anyway, but does this sound about right?
What are the pro’s and cons of SWA buried against cable in a long flexible conduit?
Dave
Dave
