I've had an electrician round to do some work in my shed, to replace two double sockets on an existing socket circuit in my shed. The electrician says that the SWA supplying the shed is too small - 4 x 1.5mm to feed a socket circuit in my shed, but is fine for lighting.
He tells me that the cores have been 'doubled' up to make them effectively 2 x 3mm, and the armour? has been used as CPC. The existing fuse board supplying SWA is fitted with a B20 apparently. Within the shed, the SWA feeds a second fuse board with RCD, and a socket circuit B20, and a lighting circuit B6.
The electrician would like to replace the SWA for a larger cable size, and I agree this would be preferable, but is it against regulations to double up in this way?? To replace the armoured would me ripping my house and driveway apart!
Thanks in advance
Kellie
Thanks in advance
Kellie
