Hi
I've scanned through some of the previous posts and noted when people wish to run armoured cable to sheds. Noted the 10mm recommended thickness as well that seems to be mentioned in most instances.
I have about 5 double sockets, all weatherproof linked with SWA underground cabling running throughout my garden, all tested by a spark and certificate provided. The intention is to use these sockets merely to plug in lighting and such that I don't have to bother getting a spark to connect fixed lighting connections each time.
I also would like to light a few garden sheds using the same sockets by running 2.5 mm swa underground from one socket (via a three pin plug) to a shed and simply having those sheds lit by way of an extension from one of the sockets. All sockets are on a 15amp (I think) circuit.
My question is would 2.5mm 3 core SWA be sufficient for this purpose? I've seen smaller armoured cable but I'd like to run it underground as opposed to surface.
