Hi guys.
A friend has got a shop and wants to install an open vent system for cold and hot water only and NO ch. As there is not going to be any ch, is it ok to do without the motorised valve? Thank u for your advise.
to your answer,as long as the cylinder stat turns the boiler off. no.but cant see why a costly inefficent setup would justify in the long run. a what if scenario.
The corgi man will connect up the gas pipe to the boiler but since the guy does not want any ch i thought it was possible to do without the MV and to let the cylinder stat to activate the pump and boiler when calling for hw.....i just wanted an opinion from somebody more experienced than me.
