Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I want to install a wood burning fire and connect to my existing system to warm the central heating when lit. I have a combi boiler, is there a way of doing this with a separate tank for venting etc?
Go for a stove with SCWS fitted which can be connected to sealed systems. You'll pay more for the stove but less accordingly for the installation. Check out Broseley fires who supply them and can give you details of approved installers.
This is not worth doing unless you are going to use it much of the time. The need to keep the woodburner boiler safe makes for an expensive installation, and this may well compromise the overall efficiency of the combi boiler installation.
Put in a woodburning stove by all means, but make it a heat only model. The heat will circulate through most of the house if you leave internal doors open.
