    Dismiss Notice
Wood burner & Thermal store
Discussion in 'Plumbing and Central Heating' started by neildee, 13 Jan 2014.
  1. neildee
    neildee
    4 Dec 2011
    2
    Thanks Received:
    Somerset
    Country:
    Hi All,
    I have installed a 450 litre open vented multi fuel thermal store. It has direct tappings to a wood burner 28mm gravity, a coil connected to an oil boiler in an S Plan configuration and a coil for solar which is not yet installed so the boiler coil and the solar coil have been linked to give one large coil.
    The thermal store is situated on the same floor as the wood burner within 4 meters.
    The issue I have is that when the wood burner is not lit and is cold and the store is hot, the wood burner starts warming up with the store being the heat source. I have got 750mm vertical rise straight off the wood burner then about a 3m gradual rise to the store on the flow and the return falls as low as it can off the wood burner then rises to the tapping on the store.
    As the wood burner is not used every day this is annoying because I am losing heat up the flue.
    Does anyone have any suggestions to prevent this?
    Thanks in advance.
  2. Sponsored Links
  3. dcawkwell
    dcawkwell
    2 Nov 2010
    3,422
    Thanks Received:
    516
    Humberside
    Country:
    Sounds like you have a nice gravity circuit that will work either way.
    Put a valve in the return that you can turn off that will stop it.
  4. neildee
    neildee
    4 Dec 2011
    2
    Thanks Received:
    Somerset
    Country:
    Yea that would do it!
    But would it be dangerous though if someone accidentally turned it off when the wood burner was on?
  5. Norcon
    Norcon
    17 May 2008
    8,418
    Thanks Received:
    357
    Country:
    I'd rip out the sludge bucket and find a better place for it. Usually a skip.
  6. MrTherm
    MrTherm
    20 Dec 2013
    140
    Thanks Received:
    33
    Country:
  7. Norcon
    Norcon
    17 May 2008
    8,418
    Thanks Received:
    357
    Country:
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
