Hi there, I am planning to install a thermal store that will be fed from a wood burner and oil condensing boiler. I understand the pricipals of the system but I see from posts on the forum you have experience of these sorts of systems and wanted to pick you brains.
I want to install a Gledhill RE (350 litre tank has been recommended to me). I don't plan on connecting solar to it yet but I like the idea of it at a later date.
1, When I install the unit will I just blank off the solar coil?
2, Will there be a cold spot at the bottom of the tank during the summer when I am not using the wood burner? (The oil boiler fixings would be above woodburner return / the solar coild at the bottom would be redundant) and would this cause a problem?
3, What are the input / output diameters for the DHW coil?
4, Do I need to intall a heat leak radiator?
5, What diameter pipe would I need to use for the space heating circuit?
Any other advice would be greatfully recieved.
