wood/laminate flooring & retaining access under floorboa
21 Jan 2007
Manchester
Hi. I have moved into my first house and it really needs the front room carpet sprucing up. I was thinking about wood or laminate flooring though.
It's a 1920s semi though and there's a ~0.5meter cavity below the floorboards, through which central heating pipes, TV, satellite and mains cables run.
At the moment there are a few floorboards that are easy to lift up on each end of the room, and this is how I was able to find & attach to the old TV aerial wire (previous owner used Virgin Cable).
I'm worried that if I just get someone in to do flooring, I'll lose access to this cavity.
I could just have the floorboards improved/replaced/sanded, but I'm concerned about draft and noise from/to next door (this is another problem.. I can hear everything my neighbour does! I'll probably get the party wall double-dry-lined/green-glued at the same time).
Is there a simple/common solution? Or do I have to pretty much risk damaging the flooring if I need to get underneath it, or have to call a flooring person out every time?
Thanks,
Carl
Not that I an aware of.
Yes and even if you have a floating floor, you are likely to need to glue the tongues which will probably defeat your "flooring-person" as well.
You could have a trap door under your sofa, or if you have a dinning table at one end, you could have a rug under the table with a trap door under that
I have also seen a trap door with a flush handle for access to an internal manhole in someone's lounge.
Andy
OK thanks guys. So basically, I should probably just, erm, make sure I've got the wires that I need before I do the flooring?
I'm thinking of doing it myself, with tongue & groove veneered/"engineered" oak flooring.
take the skirting board off before you start, then when you refix it can conceal the cut ends.
BTW it would be a bit of extra work to make a couple of trapdoors while you are doing all the rest, but far less trouble than having to do it in an emergency.
Last time I had a new floor, I had a hatch for a floor safe. One of my neighbours once left access for wine storage.
you're right, it was just a lift-out I've got. Hinges and chamfered edges are too much work.
