Wood posts into stone wall
23 Jan 2003
I’m fixing gate posts for a single 5ft picket gate both onto stone walls.
What fixings do you recommend plz?
Sorry no. It’s a side gate for a stone cottage ( house wall on one side and 4ft boundary wall on the other.
how big is the gate going to be
the 4ft boundary wall - is that a single wall or ????
Will it be hinged from the cottage wall
I have used an chemical anchor fixing and studs on 2 gates so far ,
the first side gate i put up - 6' tall - I tried a lot of different fixings - none lasted
then i used the anchor chemical fixing
so a stud these
and then anchor fix - this
I then using a fostner bit countersunk so the nut was below the post - Cut the stud
then hinged the gate
I used 3 bolts both times
But pictures of what you have would be good
