Sorry is this is a silly question but do I need a connector to join the flue to the woodburner or can I just connect one to the other? Reason for asking is that we have just purchased a stove and were told by the seller we would need a connector or the flue wouldn't fit. When we got the stove home, however, the flue pipe (which we already had) fitted perfectly; if anything it seems to be a better fit without the connector. In case this is relevant:
The flue pipe is 100mm diameter
The connector is a 'female -female' vitreous enamel one 102 mm in diamer
The stove is a pot bellied cast iron one with a top outlet.
