Wooden door thresholds - decorating
9 Oct 2006
Southampton
We have flat wood for internal door thresholds. These seem to be painted with white gloss, just like the door frames.
A year a go, I re painted some of them with standard gloss. These ones have gone black with dirt and wear. While the others that I did not paint are not affected.
I realise now that using normal gloss is not the right way to paint these thresholds, but other than floor paint (which I cant get in white gloss) im not sure what to do.
Someone said I should varnish normal gloss, but i didnt know you could do that. HELP!!
I have applied Dulux undercoat then Dulux gloss on thresholds and they have lasted years. Go for Oil Based Und & Gloss.
An update:
Thanks Third_eye, you are right. The paint i used before was Dulux one coat, which contains some sort of undercoat. Apparently, its quite soft.
I went and bought a tin of Dulux Gloss oil bassed and have applied it to the thresholds. I was told that the oil bassed stuff is the most durable gloss.
It is too early to say how they will wear (as having decorated them, I am trying not to walk on them!!).
One other point to note, the black marks that the dulux one coat painted threshold had actually washed off with Sugar soap. Although the buildup of the marks is still unacceptable to me, even if they do wash off. The other thresholds in my house dont suffer from marking.
I will post back in a few weeks and let everyone know how they are!!
