wooden lean to roof
10 Jul 2009
Nottingham
Hi everybody thanks in advance for any advice, now here’s my thing
I am about to build my first wooden lean to (its for my patio are in the garden), it will fasten to the back of my house and I want some sort of see through removable panels all round so on the cool days we can still sit there even if it’s a bitty windy but on warmer days we can take them off or hinge them open to have a little bit of a breeze, so any ideas on this in general would be great,
Now my main thing is I was thinking of a Perspex roof and I am not sure how to put this up with a slope to drain the water the roof I want to be permanent the size of the whole project is going to be 5m wide 2.5m in height at the house and 3m out,
If anyone has built anything like this or has some photos I would really appreciate that thanks.
maybe I have not made myself clear but I basically want to know the best way to build the frames for the whole project .spacing’s for the roof etc. and how to fasten the roof to the house with a slope for drainage without leaving room for leaks, it’s the slope that most concerns me as if I was going to do a flat roof this would not be a problem
I would look on ebay/gumtree for some cheap 2nd hand french type doors, this could save a lot of work, and make a framework to suit.
If you want the roof to let light in get some good quality corrugated opaque plastic/fibreglass roofing sheets. The roof purlins are normally spaced at 3-4ft but it will depend on the sheets used
If I've understood your plan correctly, you're intending sloping the roof towards the house? Wouldn't it be better the other way round?
no it will be sloping away from the house dont want to damage the brick work and want to add some propper drainage hopefully, :D
Another idea is, you often get basic 2nd hand conservatories for sale cheap, if you got one about the size you want it could save a bit of work
the thing is with a conservatries I won’t be able to open it up on very hot days, I am thinking of a waist height surround most the way round and that above waist height can be fully opened on hot days and keep the waist height surround so it can have good air flow and feel its outside but then closed up when there is a cool breeze/wind but get the heat, today was probably a good example for a warm day behind glass/plastic/Perspex, round our way, of a day you would keep it closed but still use it. Plus it’s got to be classed as a temporary structure
Also should I bury the posts with concrete or would it be ok to use theses metal thing to put posts in?
