Wooden worktop joints
18 Jan 2006
Cumbria
I want to replace current laminate worktops with wooden ones. I am going to fit square edge worktop to simplify the corner joints. Has anyone felt the need to put a small radius or chamfer on the worktop top edge after fitting?
Never done it but I would guess it looks better and may prevent the corners getting chipped.
Fair enough. I might not feel the need to do it either. Initially I had wondered whether some people might run a router around the worktops to put on a small chamfer. However, considering this would be done after a lot of work had been put in fitting the worktops, there is a small risk that something could go wrong so I would probably just take off the sharp edge by hand.
definitely take the sharp edge off mate, just a light pass with a block plane or a 180-grit sanding block to ease the edge. dead-square 90 degree edges on solid timber chip really easily if a mug or pan bangs against them, and it feels much easier on your wrists when you're leaning over it. just keep it subtle and give it a good coat of oil straight after.
I normally use a 5mm rounding over bit in a 1/4 inch router around the top aris's and lightly sand the under aris's with 80 grit sandpaper.
I do the rounding over after the worktops are bolted!
