Woodwork undercoat/ Primer application with roller?
18 Feb 2013
Hampshire
Hi
I was wondering if it is a good idea to apply the undercoat/ primer layer to my skirting, door architrave and woodwork on under stair cupboard with a roller.
I plan on using Bulls Eye® 1-2-3 Plus, product info says it can be applied using spray gun, roller, bush or pad.
I will use a water based satin as a finishing coat, but wondering if I would be better off using a roller or brush to apply the under coat/ primer.
If you do use a roller you need to lay it off with a brush to avoid an orange peel texture.
123 is fairly easy to apply and rubs down fairly flat as well, just don't put it on too thick.
