Hi there, when the heating is recharged it looses pressure as you watch the guage. There is no water from the pressure release pipe outside.
Any ideas?
If the gauge is telling the truth then there must be a leak somewhere on the system. If the leak is above ground it will become obvious pretty soon if the pressure is dropping quickly. If the leak is under the floor then it may be more difficult to find.
