Word of advice. Get Worcester in, It will cost you 250 tops. They have two charges 185.00 for breakdown inc 3 parts but go's up to 250.00 if it's a heat exchanger. Quite often the burner, insulation, PCB, Baffles are all done at the same time...no extra.
When you phone Worcester tell them you know it's the Gas/water heat exchanger that's leaking so they can order the part and allocate the time for the engineer to do the job first visit. Have your boiler make and serial number handy when you call.
WB have done half the work... due back tomorrow to finish off, at last. I reckon its taken 6 hours all together as they keep not having the right parts in the van
Do you reckon the power flush we had done (by others) may have caused heat exchanger to start leaking?
Congratulaitons in anticipation...hope it all goes well, savour the first 5 golden years! ours are 11 and 13. Wonderful.
