hELLO ALL,
I HAVE THE ABOVE BOILER WHICH IS 2 YEARS OLD BUT IT DOESN'T WORK! THE IGNITION PROCESS WORKS, THE FAN RUNS BUT THE BURNER WILL ONLY STAY LIT FOR 5 SECONDS OR LESS THIS IS WITH BOTH C/H AND H/W SET TO CONSTANT IT IS THE SAME IN ANY SETTING.
THE ONLY FAULT I CAN SEE IS THERE IS SLIGHT BROWNING ON PART OF THE PCB BUT NO BREAKS IN THE SOLDER. THIS HAPPENED TWO WEEKS AGO AND AFTER ALOT OF HEADSCRATCHING AND FIDDLING IT SORTED ITSELF OUT, TODAY IT HAS HAPPENED AGAIN.
ANY IDEAS?
ANY IDEAS?
