Old heatlsave 15/19 (1991 vintage) with B11 burner running on 35 sec gas oil, as was instructed by previous owners of the property. Due to the price difference kero/gasoil I would like to change the burner to run the cheeper fuel.I removed the nozzle and it is marked as follows:
0.6 80 H 2.37kg/h. note (80 degrees H no degree button on keyboard!)
The manual I have is for the later heatslaves which list B9B burner for the 15/19 and therefore I have no reference as to which nozzle to fit.
Checked pump running press with a gauge and is currently set at 105psi. What would happen if I start using kero with the boiler nozz /airflow settings as it is?
Any advice would be appreciated.
