worcester 24cbi boiler
7 Jun 2009
worcester 24cbi boiler comes on for 2 seconds then cuts out it does this 5 times by itself then goes to lock out can anyone help
Is the lockout light flashing or steady?
Does the boiler have this problem when cold/hot?
When you say lights for 2 seconds - are you going by the 'Burner on' light?
When was the appliance last serviced?
hi, lockout light constant. fan comes on burner comes on for 2 seconds then cuts out,fan stays on, berner comes on ,2 seconds then cuts out trys this five times then locks out
Ok you missed a couple of my questions - I'll guess that this problems happens regardless of system being hot/cold. I imagine there is NO heat coming out of the boiler due to short burner cycle.
The constant light stands for Overheat, but I don't see why it would get to that stage after only 2 seconds...
Has any work been done on the boiler recently?
If you leave the boiler for a while (to cool), then have someone reset it whilst you touch the pump (in airing cupboard or near boiler), can you feel the pump vibrating?
Do you have a sealed system or open vented?
Do you have a Y or S plan system (one 3-way valve or two 2-port valves).
If you're unsure about the above - quick google will fill you in
