Hi,and thanks for having me on the forum. The above boiler is now very old being in a static caravan lpg,open flue. Its started to lockout after a min or so with flashing DHW light. Reset on the boiler does not work,has to be switched off at mains. The manual points to fail point J which says possible flue restricted,and/or restriction around gas water heat exchanger, failing this,gas safety device at fault or circuit board. A replacement board was fitted and any restrictions checked but still same fault and strangley still doesnt work on reset button. All is left according to manual is the gas safety device. i have read some previous post back in 2005 but dunno if ever resolved back then,any help appreciated.
