I can only get the central heating to work if the DHW has been running first to get the gas to flow and ignite, when the water is turned off the boiler stays alight and the radiators heat up.
I figure this rules out the programmer (timer on the boiler) as I can also use this to turn the heating off once it's on.
Rules out the thermostat - no roomstat and the stat on the boiler is turned up to max otherwise the CH wouldn't work at all...?
There's 240V going into the gas valve for DHW and stays like that when the CH is set to on when DHW turned off again, but no voltage seen at the gas valve when I try to get CH by itself. But the fan is going.
Does this point to the pcb or is there something else I can try?
Started a couple of days ago, no changes made to any of the system.
