I need some advice on a worcester 24 i fault please lads. It is standard 24i now what happens is for c/h and h/water it goes through its sequence it starts to spark and then it dosent ignite,now i was thinking gas valve but if i blow down the aps tube it starts to spark then fires up every time and will stay on until you turn it off but it wont fire up itself but blow at aps and fires every time i changed the pcb only because i had one and its only a 10min job,obviousley i put the old one back on but what do you lads think.I rang technical and he said"ring me from the job"so i did but he was as stumped as i am,what way shall i go now?. Ive cleaned the tubes and venturi out its very strange
