Hi
Switched on the central heating today to make sure it was working for the winter.
Turned the water temperature setting fairly low and swiched it on. The pressure went from 1bar to over 2bar even at the low temperature setting so would like to check the expansion vessel pressure.
I assume its the valve on the left at the top of the boiler. However its oversized to fit a normal tyre pressure guage/pump to. Even it the guage would fit there is no central pressure release pin so wouldn't be able to measure the pressure.
Am I looking at the right thing and if so is there an attachment you need to buy to allow a normal tyre guage/pumps to fit?
