Folks, I'm new here, and have a quick question.
We have a 28cdi. For some time it has had a very small leak from the left hand side (looking towards the front) with brown treacle like stuff (sticky waxy sort of stuff) collecting in the bottom cover and dripping out. Plumber came yesterday to service boiler. He drained it, stripped the pump, fitted new gasket seals to connectors. There was a lot of banging around with a hammer to undo things. Job done.
In passing he mentioned that the diverter valve is often the culprit and is a pain in the butt to sort out, usually better to replace whole valve rather than just diaphragm - and it's obvious why when you see what needs to be done.
Anyway, expecting all to be ok now the pump was done, I checked under the boiler that evening, and there's a new leak - from a different place - guess where......the diverter valve. This was fine before. Spoke to plumber again today and he reckons it's nothing he's done - just that draining and refilling the boiler has caused the new leak (not the hammering around when he did the first job). So it looks like I'm now in for a new diverter valve.
I have a couple of questions.....
1. is it possible that draining and refilling has caused the leak?
2.could too much hammering around have aggravated the situation?
3. how much am I likely to be looking at to have the valve replaced?
Cost so far has been £75+ vat for service, pump strip and new hasket.
Many thanks in advance.
Pete
Pete
