My system lost pressure because of bleeding a radiator. I have got the pressure back up from zero to 2. Switched off and back on, also held down flashing reset button, but it is still flashing once per second. How do I reset it and get it working again?
The reset button on these is a very poor design, the shaft that presses the micro switch to reset is tiny and it might not be lined up, gently move the red button around and gently press it in and hold for a few seconds then release, do not push it in too hard
The light goes off when I am pressing it in so I think it is lined up properly. The light is still coming back on after I try to reset it. Any idea what might be wrong and how I can get it going?
