Worcester 28i
14 May 2008
Monmouthshire
Hi, all
I have a Worcester 28i combi.
I am having a devil of a job getting hot water intermittently.
It goes to fire up, there's an initial 'whoomph' of the gas lighting and then a 'clicking' from behind the temp knob and it turns off.
It only happens intermittently. I see PCBs for sale - is this my likely problem?
Tks for the quick response.
Whilst waiting I had a good search around this forum (it's good 'ere innit?) and found some advice to turn everything off for 5 mins.
Did that and we're working again now.
I'll keep an eye on it.
Cheers
Bought one new, fitted today, works a treat.
Now I've just got to work out why the pressure's playing up in the central heating.
The dial reads low, so I top it up.
A few days later it needs topping up again!
Then I find the overflow outside is discharging.
Am I simply adding too much water to the system?
Refer to FAQs on repressurising expansion vessel. Try snapping the PRV shut a few times and see if it reseals, otherwise this will need replacing.
