gas4you said:
Depending how far the meter is away you may even have to go up to 28mm.
The 15mm pipe would 'starve' the boiler of gas so at best it would not run efficiently and at worst not work at all.
As all boilers now have to be notified to corgi I doubt any legitimate installer would fit it to this 15mm pipe.
Worcester would not honour the warranty if there was a combustion problem either.
Thank you gas4you for your frankness, and this basically means no new boiler for me, and because for the past 20 years my non condensing boiler has worked perfectly with the small diameter pipe, it's now going to have to continue because there's no way I can have the house wrecked fitting a new pipe.
The new boiler is still sealed in it's box, and hoping the supplier will take it back for a refund.
Regards Ravel
