worcester 350 fails to ignite for hot water
28 May 2004
hi there got same problem as brian101 check it out.cheers
, Post Subject: Worcester 350 combi fails to ignite
I've got a problem on a worcester 350 combi boiler that fails to ignite for 10-20 attempts. There is just a flicker of a flame and then it dies. Eventually it fires up and then everything is fine until the system is cold again.
The process of the failing attempts goes like this:-
1) Gas valve solenoid operates
2) Regular spark every half second or so.
3) Very small flame lasts for up to a second
4) Flame goes out
5) Very rapid sparking and what sounds like a relay and the gas valve solenoid rapidly operating.
6) Go through this process enough times and eventually the boiler works normally until it's cold again.
I did find that tapping the relays when going through this process seemed to have a benefitial effect, so I replaced the sequencing board with one I got off ebay, thinking that one of the relays was sticking - no joy
I have pre-heated the flame sensor when the boiler is cold to see if that had any effect - no joy.
Any ideas gratefully received
Back to top
hi ollski ive checked temp sensor its fine.problem only when demand for hot water.but the hot water demand is fine when heating is on. ive also replaced flow switchi. i have to keep turning tap on and off until it eventually lights
it was changed a few years ago .i disconected it and tried the water it wouldnt go hot,connected on again and after a few on and offs it lights up
