Worcester 87161063560
23 Dec 2008
Sussex
Anyone changed one?
Feeling particularly cowardly as I've had a bad week.
Pin hole in the plastic manifold on a greenstar junior. It looks by the number of o rings and washers in the kit that the whole hydraulic block may have to come out unless someone knows different.
Any tips/advice apart from don't do it.
Dave
The left side one?
Dead easy, the hardest part is swinging the copper pipes forwards from under the manifold. Theres a small lip on the isolation valves so you have to lift the pipe slightly and twist forwards then pull out the manifold. They will be uber tight.
Easy job, you don't have to remove the whole bottom end. Replace both the rings on the bypass. Most difficult bit is removing the flow and hot pipes from the LHS manifold...grips often needed but don't chew them up. Don't forget vessel re-charge.
