Having a problem with a 28CDI boiler and was just looking for some advice before having to spend anything on callout's etc.
For a bit of history, the boiler has worked flawlessly so far as i can tell, and even when an engineer came round to inspect it, and found the pressure gauge was reading zero, the system still seemd to work fine, the radiator's warmed up and hot water was alway's coming through. He didn't seem to think there was anything to worry about so i didn't. However, last night one of the radiator's was quite cold, even with the heating on so naturally i assumed trapped air and went to bleed it. Opened the bleed valve (heatig was turned off at the time of course) and sure enough air came out, so letting it drain the boiler made kind of a gurgling sound, like water was being sucked through something and eventually water started coming out of the bleed valve. I tightened it back up with it being late i didn't switch the heating back on.
Now, to this morning. I went and switched the heating on for a bit and everything seemed to start up fine but after about 10 second's, the flame detection light goes off and there is no hot water/heating coming through, although the light to say CH is on stay's light and the boiler does make the normal noises like when it switches the heater off once the right temp has been reached. I have trid using the reset buton just incase but to no avail. Everytime i switch the heating or hot water on the flame detection light stay's for around 10 seconds then goes off resulting in no hot water/heating. Now i've searched everywhere for the filling key but have been unable to find it so will speak to the landlady see if she has it but is there anything else you can suggest i check or try before ringing and engineer ?
Any advice you can give would be most appreciative
Thank's
Mark
Thank's
Mark
