Each week I need to top the pressure up, as it drops from 1.5 to 0.5 over a week, HW & CH working fine. Boiler has not been serviced for at least 5 years. There is discharge from the pressure release valve outside - crud and steam. From reading other discussions this points, I believe, to a problem with the pressure release valve or the expansion vessel. On this model the expansion vessel is a sealed unit and replacement requires removing the gas valve, which I'm not qualified to attempt. Should I replace the prv and see if this fixes the problem and is there a test I can run first.
