Hello everyone, so I have an old WB 24CDi with a CH fault (HW seems fine).
The problem was only apparent occasionally after reaching temperature last winter but now from cold it continually attempts to go through the ignition cycle but mostly fails but with the occasional full ignition but only for a few seconds.
It doesn't lock out with a flashing red light fault but just continues to go through the cycle indefinitely.
The fan spins up at each ignition attempt and then switches off when ignition fails and does this process continually as can be heard in the video link.
My first thought was vacuum tubes or switch but with stable HW I'm guessing not.
Any suggestions on the likely cause so I can pass this on to my GSR engineer to minimise costs of return visits?
Tube to fan hard/split (see photo) but replacement did not fix the issue.
17.10.2023.mp4
drive.google.com
