Could some kind person please tell me if the boiler frost protection system in the Worcester Bosch 24CDi RSF combi boiler, also protects the radiators and pipework. There is nothing about this in the instruction manual. All it mentions is boiler protection.
Worcester Bosch technical department told me in an email, if the ambient temperature falls to 5 degrees centigrade and the boiler frost protection facility has been set, the boiler will fire up and raise the temperature within the boiler to 30 degrees. They refused to be drawn on whether this give protection for pipes and radiators.
All they said is they don't manufacture radiators or TRVs.
What I am trying to say in a nut shell is, if I turn all the TRVs on the radiators in an empty flat down to the frost setting * when the frost protection system boiler ignites the boiler will it send hot water through the pipes and radiators enough to stop them from freezing.
