First post and long, so please go easy on me.
Have Worcester Bosch 280
installed from new, it has been great.
More recently, a problem happens.
I've noticed it happens mainly when using Kitchen hot water tap - boiler is in Attic-2 storey house. Tap will be used. turned off. used again say on half or less of full flow out of the tap - and...only then only cold water comes out. You can hear the boiler (fan?) whirring but it is no longer heating. Now, this doesn't always cause problem - but seems to be the best, obvious cause.
the boiler pressure remains ok, but the flame will not ignite automatically now. It means climbing up into the attic and removing the cover (now left off) to press the red reset button after either turning a hot tap on / or hot water (so as to give the boiler the stimulus to fire up again).
Boiler fires up fine and may go a week or more- seems to be no pattern
2 gas heating guys have been and looked at it:
the first was claiming at least the expansion tank needed replacing, then 'maybe' that would work.
I have found a slightly leaking radiator(due to be done soon) which has had the valves closed now and I check the water pressure dial doesn't drop too low - if it does drop I have worked out it is due to the Radiator - but this problem doesn't seem to be linked to the pressure.
Anyway. does this sound familiar to anyone?
