Hello,
I have a Worcester Bosch 35cdi Combi boiler loosing pressure.
It all started when I took a few rads off to paint behind them, and reinstalled them.
I topped system up to 1.5bar, bled the rads upstairs after boiler was working for 1.5hrs and heating with piping hot.
The only reason I noticed was that the mrs was moaning because I put "Eco" mode on the boiler, and water would take longer to come through warm in the morning.
When I opened the panel cover, I noted the pressure was on the 0 (In the red) but the boiler didn't display any fault codes or anything, which I thought was strange.
So again I topped up the pressure and and run the boiler. The pressure increased to almost 2.1 bar, but then overnight when I come back down to check the pressure had reduced to 1.25bar.
After a little while longer the pressure has gone even further towards 1 bar. Still in the green but for how long?
I put a little plastic tray underneath the copper waste pipe outside, but only a trickle of water and I think that had something to do with the thunderstorm we had in the afternoon, so PRV seems ok.
Water does seem to trickle out of the plastic pipe which I believe is the condensation pipe next to it but would assume that is normal?
Anyone else have any suggestions as to what it could be?
Jason
Jason
