Thanks for the update.
The problem I'm having is not with the boiler - although I don't think it's range rated correctly.
We recently moved into an old 1930s place with solid walls and not much insulation.
My wife and daughter (only 2) are at home during the day, so the heating is on pretty much all the time.
The rads are also ancient, and so undersized for this draughty old place that we have to keep the heating on 24/7 - if we turn it off at night, the temp drops to 16 and it takes more than a whole day to get it back to 20.
My usage in this cold snap has been 9-10 imperial units per day (approx 300KWh). But as I said we have to keep it on ALL the time. Before we had snow (about 8 degrees outside here), my usage was half this.
We have the DT20RF thermostat and that seems incredibly eager to switch the boiler on and off. As soon as it gets to temp it switches it off, and at times it switches the boiler on for 5 min and then off again, only to do the same 15min later!
So, rather than having the same issues as you, I was interested in whether range rating it made a significant difference, simply because my boiler seems to be clicking on and off all the time either due to cycling because the rads are undersized for the boiler or because the thermostat seems to lack any hysteresis.
Anyway. I have new rads waiting to be fitted and a new DT10RF being delivered next week. Hopefully when they're installed the place will heat up quicker which means we should be able to give the boiler a rest while we're in bed!
And then looking at external insulation once this green deal thingy kicks off.
Good luck with it! Be interested if you have a breakthrough. I'll be taking a look at range rating it again once the new rads are in, although may not be necessary since we're going from about 10kw of rads up to 20ish.
