Worcester Bosch Heatslave 18/25 External Oil
4 Dec 2021
Hello, we've had an ongoing problem with the hot water. Initially it'll run hot say for 2 or 3 minutes then it loses heat becoming barely warm. Funny thing is if you restrict the flow (we have a shower head connected to the the bath) it'll stay piping hot. Bath takes an hour to fill!!
Our plumber has replaced the hot water control thermostat but that has made no difference.
Any ideas would be welcomed.
4 Dec 2021
Thanks Terry.
There has been an audible bang/thump coming from pipe work close to boiler when hot water is drawn....is that a failing heat exchanger symptom?
Easy enough to remove/clean/replace heat exchanger?
19 Jul 2007
Is there any flow to rads when heating is off but there is water demand .?
4 Dec 2021
No rads are cold when heating off and draw on hot water although Ive noticed when heating is on and there is a significant hot water draw (ie running a bath) the rads go cool.
29 Nov 2009
Shropshire
That is what happens with combi's. it is in the inherent design; priority to hot water.
