worcester DT20 programmer
8 Nov 2006
Bristol
This is the programmer that is non rf (costs about £45 and plugs into the greenstar boiler). Is it possible to wire a thermostat to it?
Has anyone done it?
You need the boiler manual - most boilers have a place to connect the thermostat - usually there is a wire link between the terminals that you have to remove (the link)
Does this mean I could just wire a thermostat direct then? Without the need for any kind of programmer/timer?
I have a worcester Greenstar 30si
Yes - As the hot water dosn't need a timer , you can controll the heating how you like.
1 Timer in the boiler with thermostatic valves only.
2 Timer in the boiler with an ordinary room thermostat
or
3 Programmable thermostat where the thermostat dose both timimng and temp control. Ususlly if your boiler already has a timer you put it to "always on" and use a programmable thermostat. This allows you to have different temperatures at different times of the day etc.
Simple thermostat only is not recommended - you do need a time control somewhere in the system.
Great, thanks for your help!
I originally thought that I could buy a plug in time clock (worcester one) and then wire the stat into that but looks more like the thermostat connects direct to the boiler in addition to the time clock.
So the thermostat wired direct would work but the control over the system would only be temperature and i wouldn't be able to time it on or off if i don't use a timer/programmer.
Thanks for your advice
