Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Either the boiler is up to temperature and switching off on its control thermostat, the pump is not circulating, or something in your external controls is failing.
Is the power on light staying lit?
When you turn on the tap, can you hear the relay clicking and is the water hot coming out of the tap?
The boiler is getting hot but you might be right with the pump not working, as i moved the diverter valve manually and the pipe in the boiler took ages to get hot. I'm not sure if a relay clicks when putting the hot tap on, i will have to go over and check, but i know that there is no hot water coming out the tap.
The power light stays on the whole time and the lockout light has never come on.
Just been over to check the pump, took the top off it and the capacitor is broke, its bust open with insides now on the outside.
Is there any reason why the boiler would keep destroying pumps as the first problem the pump was broke and kept popping the fuse, now this pump what has only been on for a week has broke too
Maybe your 'spare' pump was not as new as you thought. I can honestly say that in my working life, I've never seen a capacitor "exploded". I've seen them leaking fluid, and I've seen them scorched, especially in pumps, as they can get very hot if the pump is not circulating.
How clean is the system water? If it is dirty and you are circulating this through the pump, then this can cause the pump to seize and get very hot. That will eat pumps, and no manufacturer will honour warranty claims for such failure.
