Hi Please can anyone Help.
I have come to use my boiler to heat the central heating thats not been used for a while. (few months) and have come across a few issues and problems.
First, a couple of rads on my system are not flowing hot water compared to the rest. They seem to be getting relatively hot at the TOP, but middle to bottom is cold or just warm. Tried to bleed ( no air in them)but, didnt think this was the problem. I have checked all I can on the rest of the system for bleeds and i am convinced there are no leaks on any other rads.
Id also noticed a behaviour change with my hot water flow. The water heats when tap is turned on but the flow is far greater than it ever has been in the past. When tap is turned up full, the water is temperature drops. I have to reduce my flow to sumwhat it was was previously for it to heat satisfactory.
on closer inspection, the Pressure gauge on boiler had dropped off to almost nothing when cold. Topped up with filler to 1bar. Heating then fires up and pressure gauge very quickly rises to 3.5 and blows off to outside pressure release.
On reading through your FAQ's, it appears to me that It could be my presure vessel that needs REPRESSURISING. or maybe there is another fault. could somebody shed some light on what could be the issue relating to the above and give instructions on how to remedy.
Many thanks in advance
Lee
Lee
