Hi
I've searched through the forums on here (and in other places) looking for a solution to my problem but it seems a bit niche as I've got a fairly old (now discontinued) Worcestor 24cdi boiler.
Recently we had some pipe work done (an old pipe sealed and taken away). Boiler pressure went down to zero, we repressurised the boiler, but then had some flashing lights on the boiler.
We reset the boiler as per the instruction manual, but since then we can't get the boiler to engage whenever the shower is on (which is linked straight to the boiler).
The boiler will turn on and heat water going to the bath taps, but even then it only turns on for about five minutes then turns off, so the water runs cold.
The only way it will stay on and heat the running water is with the bathroom sink's hot tap on. If I turn that on and then run the shower, it will heat the shower water, but it's nowhere near as warm as it was before, nor as powerful
I've checked the tyre valve and it's letting out air, not water, so that seems okay ... repressurised the boiler so it's at 1.8.
We thought it was the shower itself, so got someone over to replace the taps but that didn't work (£60 down the drain). He suggested it was the water pressure coming into the house, so I've contacted Welsh Water to have a look, but their first available appointment is in 2 weeks time (which is nice and customer friendly).
It does seem like the overall water pressure to the house has gone down as the taps don't run as fast as they used to (even just cold water) and the shower is definitely less powerful.
Does anyone have any ideas? Anything I can try and fix myself?? I've checked all the pipes and can't see any leaks anywhere.
Thanking you in advance!!
