worchester heatslave
7 Dec 2010
Newcastle upon Tyne
I have a problem with a 25/32 oil fired combi, the boiler runs for maybe an hour or so then locks out , resets ok then might run for a day or so then locks out again, i have put a new nozzle in and the pump pressure seems fine . all baffles are clear and flue is not blocked. sometimes when the boiler fires up it locks out as well . any suggestions would be helpfull. :p
I'd be inclined to replace the solenoid coil, on top of the oil pump, if only to rule that out......presumably the filter at the tank is clean?
I would imagine you have a Sterling 40 burner, with a BFP 11 or 41 pump or a suntec.
John :)
