Apologies to all for my lack of clarity
javascript:emoticon('
1 old (pre 1995) worchester highflow 3.5 boiler
2 high >3bar mains cold water supply
3 pilot light often cuts out if i have the hot water running full for more than 4 minutes
4 recently changed the flexible inpipe (apologies for not using technical terms) from the mains (before this had water continuously being bled from what i presume is the water overflow system, to a runoff pipe onto the road.
5 New shower without separate flow and temp controls put in to ensuite
6 frequently pilot light goes out (I presume the same as step 3 above)
Last night I was repressurising the system before relighting the pilot light (ie 6 above had occurred) by opening the tap on 4 above ( as instructed by everybody!)
Instead of pressure rising to 1-1.5 and me closing the valve, it stayed open and the pressure guage climbed to 4.7, while I tried desperately to turn off the mains to reduce the pressure.
as you can imagine there was a noise and then I presume a gasket blew directly under the heating part of the boiler
At moderate pressure red and then black water came out and my boiler died
I havent tried to do anything with it and know I need an engineerr.
My simple question after all of the above description is
1) there is something wrong with the pressure control
i understand that the hot water and the radiator water pressures are different and at different temps in the highflow 3.5.
Is this because I am in a hardwater area and something has clogged a pipe
If so is it a major job
2) the gasket that I presume has blown directly under the boiler ( not underneath the insulated small hot water reservoir to the left): Is it an easy job to fix this
3) as I want to put in a condenser boiler that can handle the 4 beddroom 2 bathroom house in the next year when i extend the kitchen, do i bite the bullet and do it now. If so can it be moved at a later stage easily
Finally anyone recommend a qualified corgi worchester service engineer for this daunting task in the South East Wales area
hopefully this is detailed enough
thanks in anticipation
