We had a stop cock put in on the water pipe
When it’s raining and freezing cold I generally entertain indoors. Cheers for the advice though.
What is your obsession here, are you just trolling? It's a bog for his mates or kids to use on a sunny day to avoid having to go indoors it's not brain surgery.And expect your friends to go outside or are they allowed to use the upstairs toilet?
Andy
You softy! The cold makes it certain that you'll not stay long in there and block the loo for others... My gran's house always had hessian sackcloth lagging around the pipeworkIt will be very prone to freezing in a hard winter. You can put a pipe heater with a thermostat in it, but it looks like the door will be very draughty so cold air will blow in. You can lag the pipes but all that does is slow the heat loss. The roof is probably also uninsulated. You should add an indoor stopcock so you can turn off the water, preferably before it freezes, but you will need it after a burst.
You take a storm lantern down the yard with you when you make a visit, obviously.You will need a light in there if it does not already have one.
Distemper is exactly what my gran used on her loo. When it started to become a bit "gnarly" she used to scrape the flakes off with a steel wire brush, the type with a metal scraper on the end then recoat the walls. Distemper is a breathable finish, so unlike modern paints it doesn't seem to sweat when you use it on solid brick walls outdoors. It used to come from the ironmongers in a paper bag and you mixed it with water then slapped it on with a distemper brush (like a bi paste brush). The cistern used to get painted every so often with gloss paint, with the lettering would be picked out in gold paint. I only know this because I was the brush hand doing this on one occasion.The walls look to me like oil paint and distemper, paint might not stick to it well.
Or Izal... Absolute murder for the wrath of grapes!Ah the good old days of the frozen outside bog and torn off sheets of the daily mirror.
AndySer
Distemper is similar to whitewash and was commonly sold by ironmongers, at least in my part of the world in the 70s and 80s. I had a great aunt who had an outside lavvy, but hers was painted with some sort of glossy paint. It always seemed damp in there, which I always put down to the type of paintI love the gold paintwork idea on the cistern. Thanks to you and others for raising distemper paint. This is not something I’d heard of so I’m intrigued. That seems to explain why the older layers seem to have an organic feel to them.
I grew up with houses that all had outdoor toilets until I moved into a city and our holiday cottage was so remote it just had a long drop. They were all wooden structures however so didn’t feel damp so much as they might just blow away (this was in New Zealand). I might look into distemper - I see Farrow and Ball have a range of distemper paints!Distemper is similar to whitewash and was commonly sold by ironmongers, at least in my part of the world in the 70s and 80s. I had a great aunt who had an outside lavvy, but hers was painted with some wort of glossy paint. It always seemed damp in there, which I always put down to the type of paint
Yes indeed. I've seen the prices, too! And to think distemper was always the cheap option - the upper classes only used to put it on the stable walls and in the servants quarters!I see Farrow and Ball have a range of distemper paints!
